Post Build Index Writer Module
All Versions
Click for all versions
Bamboo 1.0 Documentation
Description
The PostBuildIndexWriter allows you to write your custom data for a build into the index, which allows for future retrieval in your custom Report Module. The PostBuildIndexWriter will be invoked in three places in Bamboo: when a build completes and it indexes, operations which requires a re-index of a particular build (result), and when you run the re-index all action under the Administration tab.
The PostBuildIndexWriter should always be written in conjunction with a Index Reader Module which will be able to retrieve the data in the index.
Sample Module Descriptor Element
  <postBuildIndexWriter key="cloverIndexWriter" name="Write Clover Result to Index"
          class="com.atlassian.bamboo.builder.coverage.CloverPostBuildIndexWriter">
    <description>Writes the clover result in a build results to an index document</description>
  </postBuildIndexWriter>
Enter labels to add to this page:
Please wait
Looking for a label? Just start typing.
