All Versions
   Bamboo 4.0.x
   Bamboo 3.4.x
   Bamboo 3.3.x
   Bamboo 3.2.x
   More...
Bamboo 1.1 Documentation
Index
Downloads (PDF, HTML & XML formats)
This documentation relates to an earlier version of Bamboo.
View this page in the current documentation or visit the current documentation home.
Skip to end of metadata
Go to start of metadata
Description
The PostBuildIndexWriter allows you to write your custom data for a build into the index, which allows for future retrieval in your custom Report Module. The PostBuildIndexWriter will be invoked in three places in Bamboo: when a build completes and it indexes, operations which requires a re-index of a particular build (result), and when you run the re-index all action under the Administration tab.
The PostBuildIndexWriter should always be written in conjunction with a Index Reader Module which will be able to retrieve the data in the index.
Interface
Post Build Index Writer modules must implement the com.atlassian.bamboo.index.CustomPostBuildIndexWriter interface.
Sample Module Descriptor Element
RELATED TOPICS
Bamboo Documentation
Labels
  • None
