*Product: *
| Operating System | |
| Affect Version/s | 1.2.4 |
| JVM | |
| Database | MySQL 5.x |
| Application Server | Standalone |
Error Message
java.io.IOException: Cannot run program "/home/pdp11/bin/maven/bin/mvn" (in directory "/home/pdp11/bamboo-home/xml-data/build-dir/PDP-CORE"): java.io.IOException: error=12, Cannot allocate memory at java.lang.ProcessBuilder.start(ProcessBuilder.java:459) at java.lang.Runtime.exec(Runtime.java:593) at sun.reflect.GeneratedMethodAccessor467.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.tools.ant.taskdefs.Execute$Java13CommandLauncher.exec(Execute.java:834) at org.apache.tools.ant.taskdefs.Execute.launch(Execute.java:435) at org.apache.tools.ant.taskdefs.Execute.execute(Execute.java:449) at com.atlassian.bamboo.command.Command.executeCommand(Command.java:80) at com.atlassian.bamboo.builder.AbstractBuilder.build(AbstractBuilder.java:195) at com.atlassian.bamboo.build.pipeline.tasks.ExecuteBuildTask.call(ExecuteBuildTask.java:48) at edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:176) at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:987) at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:528) at com.atlassian.bamboo.build.pipeline.concurrent.NamedThreadFactory$1.run(NamedThreadFactory.java:31) at edu.emory.mathcs.backport.java.util.concurrent.helpers.ThreadHelpers$1.run(ThreadHelpers.java:34) at java.lang.Thread.run(Thread.java:619) Caused by: java.io.IOException: java.io.IOException: error=12, Cannot allocate memory at java.lang.UNIXProcess.<init>(UNIXProcess.java:148) at java.lang.ProcessImpl.start(ProcessImpl.java:65) at java.lang.ProcessBuilder.start(ProcessBuilder.java:452) ... 16 more
Symptom
Bamboo builds will fail with the exception above.
Diagnostics/Test
Check the free available memory on your machine -
- On linux try the 'free' command
- On windows user the System monitor to determine available memory.
Root Cause
There wasn't enough memory on customers machine to run fisheye and Bamboo. So after server uptime of day or so, Bamboo builds started failing with the above exception.
Increase the available memory on Bamboo machine.
