How to create and link remote Jira Cloud issues using automation
Ask the community
While it is possible to link two remote Jira instances via app links and link existing issues it's not possible to create issues across the linked remote Jira applications.
Brief overview
This automation provides a solution to the limitations mentioned above. This will be achieved using 3 separate automation rules.
Rule A: This rule will be triggered when a bug or incident is created in the service desk project. It will send the new issue details to the software project on the remote site through a webhook.
Rule B: Will receive the information sent by Rule A, and create an issue in the software project with this information. We will also link the two issues one way. Finally, it will send back the software project issue information to the service desk project to complete the two-way linking.
Rule C: Will receive the information sent by Rule B, and complete the two-way linking.
During this article, we will refer to the service desk instance as local and the software instance as remote.
A bit of groundwork
  • Make sure that both (local and remote) Jira Cloud applications are linked through functional Application Links.
  • Make sure that you have access to both the projects on the local and remote sites.
  • In steps 2 and 4 below, while setting up links between issues, a REST call will be made through an outgoing webhook with some payload. In order to get the right values for the payload parameters for your instances, first, you need to create an issue in both the concerned projects manually on each Jira site and link (both ways) manually. Once the issues are linked, you can get the right values for the parameters of the payload for the automation through this REST call Get remote issue links.  See this short video recording showing how to get this.
The automation rule
1. Set up an incoming webhook on the remote instance project (Rule B)
Setup a very basic automation rule in the remote site with one action to listen for incoming webhook. Copy the incoming webhook URL. This URL will be used on the local site to send an outgoing webhook to the remote Jira instance.
2. Capturing the incident/bug creation event in the service desk project and sending the issue data to the remote site (Rule A)
Set up a rule to send an outgoing webhook to the URL that we copied from the previous step when an incident/bug is created.
Changes in Issue Formats
As of 2024 there are 2 types of Issue formats that can be sent using "Send web request":
  • Automation Format.
  • Jira Format.
It is important to use "Issue Data (Jira Format)" to ensure that this will work as expected.
3. Extending the rule created in step 1 to create a corresponding software project issue (Rule B)
In this step, the rule will be extended to do the following.
  • Receive incoming data from the service desk project.
  • Use this data to create a corresponding software project issue.
  • Create a one-way link from remote to the local project issues.
  • Send an outgoing webhook with the newly created software project issue data back to the local service desk project.
Receive incoming webhook and create an issue in the software project
Screenshot of an automation rule configuration in Jira. The rule is triggered by an incoming webhook and creates a new bug issue in the TestProject-Kanban-classic project. The summary of the issue is dynamically generated using data from the webhook, and several other fields are populated with webhook data. The automation also includes a conditional web request based on the response status of a previous request.Receive incoming webhook and create issue in the project
Create a one-way link between Jira and service desk issues.
Screenshot of a Jira automation rule configuration for sending a web request. The request is a POST to a specific URL with custom data in JSON format.  The data includes a global ID, application type, relationship details, and a URL referencing webhook data.  The configuration also shows options for handling the response, including waiting for the response and continuing execution even if the response is not successful.
Send the newly created software project ticket information back to the service desk project through webhook
Screenshot of a Jira automation rule's Send web request action configuration. This action sends a POST request to a specified URL with a JSON payload containing issue details like SDIssueKey, SDIssueID, DevilsKey, and DevilsID, dynamically populated from webhook data. The configuration also includes a Wait for response option to delay subsequent actions until the web request completes.
4. Finally, linking the tickets from the service desk project to the remote software project (Rule C)
  • An incoming webhook is setup to receive the newly created issue data from the remote software project. This data is being sent through an outgoing webhook from the last action of the automation rule explained in the previous step.
  • Once the data is received, the linking of issues is performed through a REST API call. Ref: Get & Create remote issue links
Screenshot of Jira automation configuration showing the Send web request action. The request is a POST with custom JSON data defining a relationship between issues, using values like globalId, application type, and a blocked by relationship. The URL and data include references to webhook data, likely for dynamic linking. The configuration also includes options for authorization, waiting for a response, and validating the request. A previous action, Send web request, is also visible in the automation flow.
Last modified on Apr 2, 2025
Yes
No
